use of nebconverge.pl
hechaoyu
Post by hechaoyu »
Dear everybody!
I am a new user of VTSTTools. When I use the script of nebconverge.pl, there are some outputings and the program stop.
"Use of chdir(' ') or chdir(undef) as chdir( ) is deprecated at ..../.../.../nebconverge.pl line 27"
I don't understand this. Please tell me how to deal with such problem and let the script run well?
Best wishes!
Re: use of nebconverge.pl
It looks like a trick that we use to determine if a directory exists is no longer allowed. It does, however, appear to be a warning and not an error. Did the script not run correctly?
I'll update the script to avoid this message.
Ok, the vtstscript tar file has been updated.
hechaoyu
Post by hechaoyu »
[quote="graeme"]Ok, the vtstscript tar file has been updated.[/quote]
Thank you for your reply. Where can I download the updated script?
By the way. I run the nebconverge.pl (with the task directory moved to another computer) on another computer and it create no a directory vaspgr but a file vaspgr. I remember that in the old version, it can create a directory conatining many .eps files.
hechaoyu
Post by hechaoyu »
Dear Graeme:
Thank you for your updating. I can use the script in our computer now. It can create a directory vaspgr with some output.eps files.
Thank you very much agin!
But I still have problems to run it on my personal computer. It can create a directory with out anything. No vaspout1.eps, vaspout2.eps will be created!
You probably need to have gnuplot installed. It will not generate any graphs without out.
