Updated dimer.F
Posted: Mon May 23, 2005 8:26 pm
Improved formatting for the out.dat file was checked into cvs. I also added a routine to deal with periodic boundaries into dimer.F.
Chain.F no longer prints that it is doing an NEB calculation for regular vasp runs.
I've updated the tar file.
Re: Updated dimer.F
Posted: Thu May 26, 2005 2:32 pm
by hou
graeme wrote:Improved formatting for the out.dat file was checked into cvs. I also added a routine to deal with periodic boundaries into dimer.F.
There exists tiny bug at 218, 219 and 300 lines in dimer.F.
218 line: !subroutine Chain_Init(T_INFO,IO)
219 line: subroutine Dimer_Init(T_INFO,IO)
300 line: end subroutine Chain_Init
What is the subroutine to be defined? Chain_Init or Dimer_Init?
From the tests, I guess that it should be subroutie Dimer_Init. Is it righit?
Thanks!
Posted: Thu May 26, 2005 2:47 pm
The name of the main routine has changed over time, and the older names, such as chain_init, are still present as comments in the code.
I've removed the old calls to clearify the code, leaving dimer_init and dimer_force. This is updated in cvs. These changes should not affect the building or running of the dimer method.
mail test
Posted: Sun May 29, 2005 1:31 am
test
