TST tools with vasp 6.2.1
Neutrino
Post by Neutrino »
Dear All,
I'm trying to install the most recent version of TST tools with VASP 6.2.1. At the step:
"To build the code, the VASP makefile needs to be changed. Find the variable SOURCE, which defines which objects will be built, and add the following objects before chain.o"
I'm unable to locate the variable SOURCE at all to insert the needed modification. Any hint is highly appreciated.
Re: TST tools with vasp 6.2.1
Look in the src/.objects file.
Neutrino
Post by Neutrino »
Thank you so much!
