after CINEB run,the dimmer calculation cannot converge
Posted: Wed Dec 08, 2021 3:03 pm
Dear Professor,
I came across a problem while running dimer simulation. I am working on systerm which the hydroxyl of chlorophenol will be dissosicated on the metal oxide surface. The TS was first pre-converged to 0.3 ev/A by CINEB. I used the IOPT= 3 because IOPT=7 cannot converge. And because of the short path, I set one image between initial and final state. I checked the vibration direction and genenrated MODECAR by frequency calculation. Then I have calculated the pre-convergent structure to 0.03 ev/A in the following cases.
1. I did the CINEB calculation by the pre-convered structure, which converged to 0.1 ev/A. But the vibration analysis suggested that the vibration direction of TS has chenged: there is no tendency for hydrogen-oxygen bonds to break in hydroxyl groups. And now I want to know that if I continues to converged to 0.03, is there any point in me going on?
2. I used the structure pre-convered to 0.3 ev/A (and 0.1 ev/A)by CINEB to run with dimmer. The dimmer calculation cannot converge. The curvature is negative at first and then positive, and I checked the TS and found the TS has deviated significantly from the desired configuration. I used DRotMAX = 20(up to 50) to ensure Torque meets the convergent standard(DFNMin = 0.01,DFNMax = 1.0), but it still cannot converge. So I terminated the calculation.
For dimmer calculation, I have tried IOPT=2 and IOPT =7, I wonder why they cannot converge and what to do to be convergent. Can you give me some advice?
DIMCAR as belows:
1 1.03528 8.80664 -555.15757 -0.50637 6.11466
1 1.03528 4.53340 -555.15757 -1.58506 11.71038
1 1.03528 3.42043 -555.15757 -2.26297 3.64732
1 1.03528 2.60246 -555.15757 -2.49241 2.36270
1 1.03528 1.83164 -555.15757 -2.62759 1.69373
1 1.03528 1.57873 -555.15757 -2.67645 1.62528
1 1.03528 1.54773 -555.15757 -2.75617 1.17217
1 1.03528 1.21353 -555.15757 -2.79228 1.40054
1 1.03528 1.34245 -555.15757 -2.76781 0.95123
1 1.03528 0.96405 -555.15757 -2.81187 1.13771
2 0.57564 1.24160 -555.16256 -2.56816 1.07760
2 0.57564 1.01769 -555.16256 -2.57800 0.97444
2 0.57564 0.90613 -555.16256 -2.56972 0.74319
3 0.62516 1.96372 -555.16042 -2.32654 3.09263
3 0.62516 1.33012 -555.16042 -2.42538 0.95705
3 0.62516 0.73166 -555.16042 -2.37577 1.07178
4 0.48841 2.03484 -555.15708 -1.95254 2.58389
4 0.48841 1.44278 -555.15708 -2.06666 1.15182
4 0.48841 0.88580 -555.15708 -1.97189 0.80841
5 0.57759 2.27395 -555.15371 -1.25871 3.39766
5 0.57759 1.47895 -555.15371 -1.40859 1.13494
5 0.57759 0.90305 -555.15371 -1.35006 1.18183
6 0.49345 4.05353 -555.14977 0.22317 5.15971
6 0.49345 2.16645 -555.14977 -0.17340 2.35441
6 0.49345 1.56284 -555.14977 -0.15490 1.29523
6 0.49345 1.26222 -555.14977 -0.30739 1.49071
6 0.49345 1.40191 -555.14977 -0.22043 1.08233
6 0.49345 1.10522 -555.14977 -0.39738 1.23071
6 0.49345 1.32884 -555.14977 -0.24675 1.04351
6 0.49345 1.09615 -555.14977 -0.44215 1.05773
6 0.49345 1.27518 -555.14977 -0.26632 1.03223
6 0.49345 1.18085 -555.14977 -0.48765 1.00961
6 0.49345 1.29159 -555.14977 -0.28919 1.04259
6 0.49345 1.25462 -555.14977 -0.52168 1.00704
6 0.49345 1.29733 -555.14977 -0.31283 1.03484
6 0.49345 1.28276 -555.14977 -0.53651 0.99769
6 0.49345 1.28538 -555.14977 -0.31682 1.01493
6 0.49345 1.28022 -555.14977 -0.54669 0.97799
6 0.49345 1.26821 -555.14977 -0.32152 0.99279
6 0.49345 1.26997 -555.14977 -0.55812 0.95973
6 0.49345 1.25468 -555.14977 -0.32685 0.97228
6 0.49345 1.25616 -555.14977 -0.56520 0.93979
6 0.49345 1.24007 -555.14977 -0.32992 0.95623
6 0.49345 1.24307 -555.14977 -0.58536 0.91928
6 0.49345 1.22749 -555.14977 -0.35158 0.94983
6 0.49345 1.24512 -555.14977 -0.59283 0.91708
6 0.49345 1.21753 -555.14977 -0.35325 0.93465
6 0.49345 1.23065 -555.14977 -0.59591 0.90179
6 0.49345 1.20536 -555.14977 -0.35279 0.92282
6 0.49345 1.21982 -555.14977 -0.59943 0.88970
6 0.49345 1.19349 -555.14977 -0.35323 0.91094
6 0.49345 1.20786 -555.14977 -0.60308 0.87969
7 0.40485 1.51113 -555.14793 0.03619 1.56766
7 0.40485 0.81780 -555.14793 0.01435 1.07493
8 1.41529 11.02374 -555.10140 3.82626 8.28236
8 1.41529 2.92484 -555.10140 2.21999 5.99622
8 1.41529 3.57828 -555.10140 1.97186 3.62519
8 1.41529 2.14794 -555.10140 1.80653 3.42953
8 1.41529 2.57967 -555.10140 1.63525 2.75356
8 1.41529 2.19717 -555.10140 1.55361 2.04578
8 1.41529 1.96835 -555.10140 1.45552 2.87763
8 1.41529 2.29634 -555.10140 1.40386 1.67855
8 1.41529 1.55500 -555.10140 1.29419 3.47400
8 1.41529 2.51936 -555.10140 1.24096 1.61816
8 1.41529 1.30197 -555.10140 1.14736 4.70519
8 1.41529 2.87725 -555.10140 1.06576 1.63383
8 1.41529 1.07677 -555.10140 0.96238 8.37171
8 1.41529 3.42107 -555.10140 0.81925 1.81906
8 1.41529 0.83440 -555.10140 0.69471 5.06695
9 1.59183 2.36575 -555.06070 0.66965 1.73657
9 1.59183 1.28377 -555.06070 0.58400 1.86370
9 1.59183 1.37500 -555.06070 0.54622 1.05380
9 1.59183 0.95381 -555.06070 0.52915 1.77333
10 1.69188 1.98744 -555.00353 0.56032 1.29322
10 1.69188 0.97089 -555.00353 0.52345 2.34731
11 1.82425 1.96738 -554.92889 0.55420 1.21945
11 1.82425 0.91983 -554.92889 0.48846 2.53677
12 2.02095 1.96734 -554.84043 0.53960 1.22204
12 2.02095 0.94625 -554.84043 0.47935 2.88912
13 2.27574 2.01246 -554.74200 0.48353 1.17438
13 2.27574 0.89594 -554.74200 0.44290 3.75723
14 2.61732 2.23424 -554.63906 0.37250 1.27631
14 2.61732 0.90503 -554.63906 0.32817 2.84233
15 2.82279 1.76566 -554.53778 0.28743 1.22465
15 2.82279 0.89116 -554.53778 0.23886 1.29287
I have attached the tar file of my calculations. I would be grateful if you could help me resolve this.
DIMCAR as belows:
