VTST 2.04b-VASP5.2.12 compiling error
kevinnus
Post by kevinnus »
Dear All,
I tried compiling VTST (2.04b) with VASP5.2.12 on our cluster (Centos, openmpi, ifort, and mkl), but failed with below error information:
chain.F(531): error #6460: This is not a field name that is defined in the encompassing structure. [MPMD_CLIENT_RANK]
mpmd_client_rank = comm_chain%mpmd_client_rank
compilation aborted for chain.f90 (code 1)
make: *** [chain.o] Error 1
Could you please help to look into this problem and give me some suggestions?
Thank you very much.
Kevin
chill
Re: VTST 2.04b-VASP5.2.12 compiling error
Post by chill »
Hello Kevin,
This part of the code should only compiled if you have set the preprocessor flag VASP_MPMD in your makefile, which is not set by default. Perhaps you could post the makefile you used?
kevinnus
Post by kevinnus »
Dear Chill,
Thank you very much for the helpful suggestions.
You are right that the problem is due to the unfavorable preprocessor flag in the CPP, and I finally complied the code successfully after I removed the flag.
Thanks again.
Best regards,
Kevin
xfhao1980
Post by xfhao1980 »
I have encounterred the same problem on the compiling, however, I did not know how to change the makefile, which unfavorable preprocessor flag in the CPP should I delete? Thanks in advanced!
cheers
xianfeng
