error message:(In vasp.pm::read_poscar, cannot open 'filename'
Xingru Tan
Post by Xingru Tan »
Dear all, I encountered this problem when I am trying to use the script nebmake. Error message appears(In vasp.pm::read_poscar, cannot open 'filename'). Can someone please help me?
Re: error message:(In vasp.pm::read_poscar, cannot open 'filename'
This may be related to how the script should be used. Make sure that you are including arguments of (1) the initial state POSCAR file; (2) the final state POSCAR file; and (3) the number of images. An example would be:
nebmake.pl POSCAR_ini POSCAR_fin 6
Note: we should provide a sensible message if these values are provided - I will do that.
Xingru Tan
error solved. So turns out the error is due to typing the wrong dir of the two POSCAR file in the command. Thank you so much.
