Error running dimrun example VTST 2.04b & 2.03b VASP 4.6.36
mtgarvey
Post by mtgarvey »
I have two versions of VASP 4.6.36 compiled on different clusters with different versions of VTST (2.03b and 2.04b). Both give me the same error when I try to run the example contained in dimrun.tar.gz downloaded from the UT site. The stdout is given below:
VTST 2.04b
running on 16 nodes
distr: one band on 1 nodes, 16 groups
vasp.4.6.36 17Feb09 complex
POSCAR found : 2 types and 5 ions
The IMAGES tag should not be set for this implementation of the dimer method.
VTST 2.03b
running on 12 nodes
distr: one band on 1 nodes, 12 groups
I have seen in a previous post that using MPI_CHAIN could cause this. There is no -DMPI_CHAIN in my makefile.
I do not have any other example files to run, but the compiled code does run the VASP bench_Hg example properly.
Is there anyone who has an idea as to what is causing this? Thanks in advance for any advice.
Mike Garvey
University of Wisconsin-Milwaukee
Re: Error running dimrun example VTST 2.04b & 2.03b VASP 4.6
Do you have the IMAGES tag set in the INCAR?
mtgarvey
Post by mtgarvey »
Professor Henkelman,
Thanks for the swift response. The IMAGES tag is not set in the INCAR file. Sorry, I should have stated that right away. I have included the contents of the INCAR file below, it should be the same as it is in the example.
INCAR
SYSTEM = Typical Dimer Run
IBRION=3
POTIM=0.0
ISYM=0
NSW=600
EDIFF=1E-7
EDIFFG=-0.001
PREC=Norm
LREAL=.FALSE.
LWAVE=.FALSE.
LCHARG=.FALSE.
# DIMER PARAMETERS
ICHAIN=2
DdR=0.005
DRotMax=4
DFNMin=0.01
DFNMax=1.0
# OPTIMIZER PARAMETERS
IOPT=2
This is very strange. In fact, I don't think that MPI_CHAIN is ever set anymore. So I'm not sure how your compiler is including the statement which is printing the message.
If you have time to run a check, I would be interested to know if it is fixed when you remove the white space before the
#if defined(MPI_CHAIN)
#endif
in dimer.F so that it reads:
#endif
If this doesn't fix it, you can delete everything between and including those lines. This should really be cleaned up in the code anyway.
mtgarvey
Post by mtgarvey »
> #endif
> #endif
This worked for 2.03b. I was able to run the dimrun example and it seems to be in reasonable agreement with the output from the website. Thanks for the help, I will pass this along to our hpc facilitator to see if it solves the problem with 2.04b on our larger cluster.
I have tried it on 2.04b on our departmental cluster and I am getting a new error when compiling. However, I cannot be certain it is related to this because I am not sure if I ever successfully compiled 2.04b on our cluster. I will include the error below. Maybe it will be obvious what the problem is.
Error when compiling VASP 4.6 w/ VTST 2.04b
dimer.F(494): error #6460: This is not a field name that is defined in the encompassing structure. [TYPE]
IF (T_INFO%TYPE(1)/=' ') THEN
dimer.F(494): error #6158: The structure-name is invalid or is missing. [T_INFO]
compilation aborted for dimer.F (code 1)
make: *** [dimer.o] Error 1
Ok, that we have seen; here is the fix:
viewtopic.php?f=2&t=1185
mtgarvey
Post by mtgarvey »
Thanks, that seems to have done it. I only had one more small issue after that. I had to remove the white space in front of all of the #if and #endif lines in chain.F Now both versions can run the dimrun example and give the same results which seem to be close to the results from the website.
ckande
Post by ckande »
I also faced the same problem with VASP 5.2.12 and Intel 12.1.1.256. The issue got fixed after removing the lines with #if defined (MPI_CHAIN)... #endif in dimer.F.
mwchang
Post by mwchang »
[quote="ckande"]I also faced the same problem with VASP 5.2.12 and Intel 12.1.1.256. The issue got fixed after removing the lines with #if defined (MPI_CHAIN)... #endif in dimer.F.[/quote]
I also encountered the same problem.
As your suggestion, It can be solved by removing the lines of #if defined (MPI_CHAIN)... #endif in dimer.F
Thanks.
