VTST tools (vtst-code180) with VASP 6.2.1
uthpalah
Post by uthpalah »
Dear VTST community,
I have been using VTST tools vtst-code180 with VASP 5.4.4 up to now fine without any issue. Our group recently acquired VASP 6.2.1 and I was trying to recompile it with VTST sources and I encounter the following error:
[code]
mpiifort -qopenmp -free -names lowercase -assume byterecl -w -xHOST -O0 -I/opt/intel/oneapi/mkl/latest/include/fftw -c main.f90
mpiifort -mkl -o vasp c2f_interface.o nccl2for.o simd.o base.o profiling.o string.o tutor.o version.o vhdf5_base.o incar_reader.o reader_base.o openmp.o openacc_struct.o mpi.o mpi_shmem.o mathtools.o hamil_struct.o radial_struct.o pseudo_struct.o mgrid_struct.o wave_struct.o nl_struct.o mkpoints_struct.o poscar_struct.o afqmc_struct.o phonon_struct.o fock_glb.o chi_glb.o smart_allocate.o xml.o extpot_glb.o constant.o vdwforcefield_glb.o jacobi.o main_mpi.o openacc.o scala.o asa.o lattice.o poscar.o ini.o mgrid.o setex_struct.o xclib.o vdw_nl.o xclib_grad.o setex.o radial.o pseudo.o gridq.o ebs.o symlib.o mkpoints.o random.o wave.o wave_mpi.o wave_high.o bext.o spinsym.o symmetry.o lattlib.o nonl.o nonlr.o nonl_high.o dfast.o choleski2.o mix.o hamil.o xcgrad.o xcspin.o potex1.o potex2.o constrmag.o cl_shift.o relativistic.o LDApU.o paw_base.o metagga.o egrad.o pawsym.o pawfock.o pawlhf.o diis.o rhfatm.o hyperfine.o fock_ace.o paw.o mkpoints_full.o charge.o Lebedev-Laikov.o stockholder.o dipol.o solvation.o scpc.o pot.o tet.o dos.o elf.o hamil_rot.o bfgs.o dynmat.o instanton.o lbfgs.o sd.o cg.o dimer.o bbm.o fire.o lanczos.o neb.o qm.o opt.o chain.o dyna.o fileio.o vhdf5.o sphpro.o us.o core_rel.o aedens.o wavpre.o wavpre_noio.o broyden.o dynbr.o reader.o writer.o xml_writer.o brent.o stufak.o opergrid.o stepver.o chgloc.o fast_aug.o fock_multipole.o fock.o fock_dbl.o fock_frc.o mkpoints_change.o subrot_cluster.o sym_grad.o mymath.o npt_dynamics.o subdftd3.o subdftd4.o internals.o dynconstr.o dimer_heyden.o dvvtrajectory.o vdwforcefield.o nmr.o pead.o k-proj.o subrot.o subrot_scf.o paircorrection.o rpa_force.o ml_interface.o force.o pwlhf.o gw_model.o optreal.o steep.o rmm-diis.o davidson.o david_inner.o root_find.o lcao_bare.o locproj.o electron_common.o electron.o rot.o electron_all.o shm.o pardens.o optics.o constr_cell_relax.o stm.o finite_diff.o elpol.o hamil_lr.o rmm-diis_lr.o subrot_lr.o lr_helper.o hamil_lrf.o elinear_response.o ilinear_response.o linear_optics.o setlocalpp.o wannier.o electron_OEP.o electron_lhf.o twoelectron4o.o gauss_quad.o m_unirnk.o minimax_ini.o minimax_dependence.o minimax_functions1D.o minimax_functions2D.o minimax_struct.o minimax_varpro.o minimax.o mlwf.o ratpol.o pade_fit.o screened_2e.o wave_cacher.o crpa.o chi_base.o wpot.o local_field.o ump2.o ump2kpar.o fcidump.o ump2no.o bse_te.o bse.o time_propagation.o acfdt.o afqmc.o rpax.o chi.o acfdt_GG.o dmft.o GG_base.o greens_orbital.o lt_mp2.o rnd_orb_mp2.o greens_real_space.o chi_GG.o chi_super.o sydmat.o rmm-diis_mlr.o linear_response_NMR.o wannier_interpol.o wave_interpolate.o linear_response.o auger.o dmatrix.o phonon.o wannier_mats.o elphon.o core_con_mat.o embed.o extpot.o fftmpiw.o fftmpi_map.o fft3dlib.o fftw3d.o main.o -Llib -ldmy -Lparser -lparser /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_scalapack_lp64.a -lmkl_blacs_intelmpi_lp64 -lstdc++ ~/wannier90/wannier90-1.2/libwannier.a
instanton.o: In function `instanton_mp_instanton_init_':
instanton.f90:(.text+0x1eadb): undefined reference to `rane_'
dimer.o: In function `dimer_mp_initmode_':
dimer.f90:(.text+0xaa7f): undefined reference to `rang_'
dimer.o: In function `dimer_mp_dimer_init_':
dimer.f90:(.text+0xc5a4): undefined reference to `rmarin_'
lanczos.o: In function `lanczos_mp_lanczos_step_':
lanczos.f90:(.text+0x40b9): undefined reference to `rang_'
lanczos.f90:(.text+0x40fa): undefined reference to `rang_'
lanczos.f90:(.text+0x4142): undefined reference to `rang_'
lanczos.o: In function `lanczos_mp_eigenvector_':
lanczos.f90:(.text+0x5d00): undefined reference to `rang_'
makefile:149: recipe for target 'vasp' failed
make[2]: *** [vasp] Error 1
make[2]: Leaving directory '/home/uthpala/VASP/vasp.6.2.1/build/std'
cp: cannot stat 'vasp': No such file or directory
makefile:146: recipe for target 'all' failed
make[1]: *** [all] Error 1
make[1]: Leaving directory '/home/uthpala/VASP/vasp.6.2.1/build/std'
makefile:13: recipe for target 'std' failed
make: *** [std] Error 2
[/code]
I followed the installation instructions given in http://theory.cm.utexas.edu/vtsttools/installation.html. I am using Intel OneAPI's Fortran compiler v. 2021.1.1.
Please let me know if I am missing something.
Thank you,
Best,
Uthpala
Re: VTST tools (vtst-code180) with VASP 6.2.1
Hi Uthpala,
Thanks for the note; I will look into this right away and get back to you. In the mean time, if you do a quick check and run 'make veryclean' before the build and see if the error remains, that would be helpful.
Graeme
Note added: no need to do any other tests. I can reproduce the problem and will be able to fix this asap.
Ok, if you are willing to try a updated version of the VTST code (v182), I would appreciate hearing if it works for you.
The new version should be available here: http://theory.cm.utexas.edu/vtsttools/download.html
Again, thanks for the note - it is great to hear about problems as soon as they arise.
uthpalah
Post by uthpalah »
Dear @graeme,
Thank you very much for your prompt response.
I compiled with vtst-code182 and it worked perfectly!
Thanks again,
Best,
Uthpala
Great to hear!
ruoshi
Post by ruoshi »
We are getting a very similar error with VASP 6.3.0 now using the latest vtstcode-184.tgz. Thank you in advance for your help!
instanton.o: In function `instanton_mp_instanton_init_.a':
instanton.f90:(.text+0x55ed5): undefined reference to `rane_'
instanton.o: In function `instanton_mp_instanton_init_.V':
instanton.f90:(.text+0x5c14a): undefined reference to `rane_'
instanton.o: In function `instanton_mp_instanton_init_.A':
instanton.f90:(.text+0x6228d): undefined reference to `rane_'
dimer.o: In function `dimer_mp_dimer_step_.a':
dimer.f90:(.text+0x4b9f): undefined reference to `rang_'
dimer.o: In function `dimer_mp_dimer_step_.V':
dimer.f90:(.text+0xa0a8): undefined reference to `rang_'
dimer.o: In function `dimer_mp_dimer_step_.A':
dimer.f90:(.text+0xfac0): undefined reference to `rang_'
dimer.o: In function `dimer_mp_initmode_.a':
dimer.f90:(.text+0x26c50): undefined reference to `rang_'
dimer.o: In function `dimer_mp_initmode_.V':
dimer.f90:(.text+0x27ab0): undefined reference to `rang_'
dimer.o:dimer.f90:(.text+0x28930): more undefined references to `rang_' follow
dimer.f90:(.text+0x2a45d): undefined reference to `rmarin_'
lanczos.o: In function `lanczos_mp_lanczos_step_.a':
lanczos.f90:(.text+0x3ed9): undefined reference to `rang_'
lanczos.f90:(.text+0x6f9a): undefined reference to `rang_'
lanczos.f90:(.text+0x6fdb): undefined reference to `rang_'
lanczos.f90:(.text+0x7023): undefined reference to `rang_'
lanczos.o: In function `lanczos_mp_lanczos_step_.V':
lanczos.f90:(.text+0xaac3): undefined reference to `rang_'
lanczos.o:lanczos.f90:(.text+0xdb5b): more undefined references to `rang_' follow
instanton.oinstanton.o: In function `: In function `instanton_mp_instanton_init_.V':
instanton.f90:(instanton_mp_instanton_init_.a.text+0x':
instanton.f90:(.text+0x55ed55c14a): undefined reference to `): undefined reference to `rane_rane_'
instanton.o: In function `instanton.oinstanton_mp_instanton_init_.V':
: In function `instanton.f90:(instanton_mp_instanton_init_.A.text':
+0xinstanton.f90:5c14a().text: undefined reference to `+0xrane_6228d'
dimer.f90:(.textdimer.o+0x: In function `a0a8)dimer_mp_dimer_step_.a: undefined reference to `':
rang_'
dimer.f90:(.text+0xdimer.ofac0: In function `): undefined reference to `dimer_mp_dimer_step_.Vrang_':
dimer.o:dimer.f90:(.text+0x28930): more undefined references to `rang_dimer.o' follow
dimer.o: In function `dimer_mp_dimer_init_dimer.o':
: In function `dimer.f90:dimer_mp_initmode_.V(':
.text+0xdimer.f90:2a45d().text: undefined reference to `+0xrmarin_27ab0'
Just to make sure, are you using the code in the main directory. There are two subdirectories, vtstcode5 and vtstcode6.1; these will not work for vasp 6.3. I know exactly what this error is related to but it should be correct in the latest code. Also, follow my advice for the other poster and make sure to to a 'make veryclean' so that you are not trying to link to old vtstcode objects. Also, as before, please contact me here, or directly, if this is not resolved.
ruoshi
Post by ruoshi »
My bad - I didn't know the main directory is for VASP 6.3. It is working for me now. Thank you for your prompt reply!
Ok, good to hear!
