Dear all and especially Prof. Graeme,
In a rutile-TiO2 2x2x2 bulk supercell that I've recently constructed, I replaced one O atom by a H atom in order to mimic the doping of H in a replacing style. After I optimized the supercell and issued the command "bader -b weight CHGCAR -ref CHGCAR_sum" to get the Bader charges of all atoms, I recieved the following messages:
GRID BASED BADER ANALYSIS (Version 0.95 11/17/15)
OPEN ... CHGCAR
VASP5-STYLE INPUT FILE
DENSITY-GRID: 100 x 100 x 64
CLOSE ... CHGCAR
RUN TIME: 1.18 SECONDS
OPEN ... CHGCAR_sum
CLOSE ... CHGCAR_sum
RUN TIME: 0.36 SECONDS
SORTING CHARGE VALUES ... DONE
CALCULATING FLUX ... DONE
INTEGRATING CHARGES
0 10 25 50 75 100
RUN TIME: 5.38 SECONDS
38 67 67 35 707.706295160000
some volume not assigned
The error "some volume not assigned" is quite noticeable. Then the Bader quit without creating the three .dat files.
How do I deal with this problem?
Regards,
Jianmin
Error message "some volume not assigned"
Re: Error message "some volume not assigned"
Hm, I don't recall seeing that error before. If you can please post your CHGCAR and CHGCAR_sum, I will look into the problem.
Graeme
Graeme
Prof. Graeme, thanks a lot for your reply. Attached please find CHGCAR and CHGCAR_sum in the compressed file.
- CHGCAR.rar
- (3.99 MiB) Downloaded 28588 times
I have the same problem on high density grids with -b weight.
Can it be solved in some way?
If you can make a problematic AECCAR0 and AECCAR2 and the CHGCAR available, I can take a look at it.
The error message mentions the density-grid size (100 x 100 x 64). So check the grid parameters are suitable for your system. You may try refining the grid to see if it resolves the issue.
