non-orthagonal unit cell
achar002
Post by achar002 »
Hi
I have downloaded the binary of the Bader analysis program (linux ifort) from the following link like a week ago http://theory.cm.utexas.edu/henkelman/r ... /index.php
Does it handle non-orthagonal unit cells like graphite?
Thanks!
The binaries on the web page do not properly deal with non-orthogonal cells. The results could be reasonble, but it is not formally correct.
If you are willing to build from source, you can use the version in cvs.
Instructions: http://theory.cm.utexas.edu/henkelman/code/
We are close to releasing this as the official version.
To use the same algorithm as what is in the binary version (but with proper treatment of non-orthogonal cells) run: bader -b ongrid CHGCAR
