Version Information
Re: Version Information
v0.28a 07/12/12
Ensured a positive volume to fix a sign error in PWscf cube files.
v0.95 11/17/15
Beta version of the weight method by Yu and Trinkle; test using the "-b weight" flag. There should be no downside to this method. The output will be more accurate due to a partial assignment of charge to bader volumes at the boundary volumes.
A vacuum level of 1e-3 e/Ang^3 is on by default to reduce the computational cost and to limit the number of bader maximum in systems with isolated molecules and a significant vacuum region. Turn off with "-vac off" or change the vacuum level using "-vac val" where val is the charge density threshold for the vacuum.
v0.95a 02/26/16
Bug fix in which negative charge density was considered vacuum. Only the standard neargrid algorithm is effected.
v1.00 01/11/17
Vaccum region is now based upon the reference charge density, if provided. Formatting of the ACF.dat file allows for larger charges and volumes. Fixed a bug that give incorrect ionic volumes using the weight method.
v1.02 09/25/17
Proper calculation of critical points, at least for orthogonal cells.
v1.03 11/13/17
Default to -vac off
v1.05 08/19/23
Proper reading of negative direct coordinates.
