Dear Admin,
I have trouble getting a correct relative value of d-band center in Cu vs. Pt.
I've chosen a fixed energy range [-15,5] eV to include all metallic d states below Fermi level and a certain amount states above.
The value for Pt is -2.29, while for Cu I get -2.21. It is in contradiction with literature reports that Cu has a lower d-band center.
I cannot find any clue why it is wrong. Is there any idea?
Thanks a lot![attachment=0]d-band-center.ps[/attachment]
d-band center of Cu is wrong
- d-band-center.ps
- (58.58 KiB) Downloaded 883 times
Re: d-band center of Cu is wrong
I just looked up an old paper by Hammer and Norskov (PRL 76, 2141 (1996)) and I see similar relative d-band values for Cu (-2.67) and Pt (-2.75).
Hmmm...
That sounds a bit weird. It is quite strange that there are many papers out there reporting rather different d-band-center value for Cu. It sort of convinced me that Cu should have a lower d-band-center and thus a much weaker H2 or O2 adsorption property.
Actually I found a picture from Hammer and Norskov that shows an obviously higher d-band-center of Cu than Pt. Definitely not the result I got.
B. Hammer and J. K. Nørskov, Advances in Catalysis, ed. H. K. Bruce and C. Gates, Academic Press, 2000, vol. 45, p. 99
Any thoughts?
Thanks for helping!
Any thoughts?
Thanks for helping!
- c5sc01227a-f3_hi-res.gif (35.74 KiB) Viewed 14540 times
