the magnetic moment
the magnetic moment
Dear Bader admin and users,
Runing Bader with "charge.cube", I can get the charge on each atom from ACF.dat. what about the magnetic moment (spin_up - spin_down) of the atom? What shall I do?
Any suggestion will be appreciated.
Best Wishes,
Fadwa
Best Wishes,
Fadwa
Re: the magnetic moment
If you have a spin density file, spin.cube , you can find the spin on each atom using:
bader spin.cube -ref charge.cube
Dear Prof Graeme,
Thank you for your quick reply.
First, I should do file "charge.cube" than I make file " spin.cube" after that I'll run bader with this order " bader spin.cube -ref charge .cube" , right or not ?
So which file can I get magnetic moment? in ACF.dat ?
Best wishes
Best wishes
Hi all,
Sorry for trivial questions but I am quite newby and a bit confused. I am also trying to calculate the magnetic moments from CHGCAR file. Regarding that I am running my calculations with LAECHG=.TRUE. tag. I will have CHGCAR_sum file at the end.
- Prof. Henkelman suggest to run "bader CHGCAR_spin -ref CHGCAR_sum". I guess to have CHGCAR_spin file I should first use the chgsplit.pl on CHGCAR_sum script then the file will come, right ?
- Nevertheless, when I convert my CHGCAR file to CHGCAR.cube and split the error message comes as :
Points in total charge density: 1.53235161082913e-15
Points in magnetization density: 3.99350522014799e-15
Number of points not same in two parts! at ./chgsplit.pl line 67, <IN1> line 99372.
- And when I use the CHGCAR file without converting to cube format code is not working...
Can anybody tell me what is the missing and I can not get the CHGCAR_spin ?
Regards
Halil
Regards
Halil
It looks like the files are not being parsed correctly. Check for obvious problems with the header (e.g. end line characters) and then we'll take a look if you post the files.
I have attached the CHGCAR_sum file, where I get by using " chgsum.pl AECCAR0 AECCAR2 ". With this I can run " bader CHGCAR -ref CHGCAR_sum " or I can convert both CHGCAR and CHGCAR_sum files to cube format and run the bader, to get the charges on ions. The first question which one will be the correct ?
The second question is about the magnetic moments. To get the magnetic moments on each ions, I need to do "bader spin.cube -ref charge.cube", how can I get the spin.cube ? In case that this file will come after running chgsplit.pl, I can not run the script. Error:
> ./chgsplit.pl CHGCAR_sum
Atoms in file: 68
Points in total charge density: 1179648
and nothing comes out.
I run my calculations with Nd,Fe and B, GGA+U and Non-collinear. Can it be the reason ?
Atoms in file: 68
- CHGCAR_sum.txt
- (21.38 MiB) Downloaded 33727 times
Please attach the original CHGCAR, AECCAR0, and AECCAR2 so I can reproduce the error.
In regards to your question, you can do the analysis using CHGCAR; there is no reason to convert the files to the cube format.
Dear Prof. Graeme, thanks in advance. I have just attached the files, looking forward to reply.
- CHGCAR.txt
- (83.2 MiB) Downloaded 34287 times
- AECCAR2.txt
- (20.48 MiB) Downloaded 34030 times
- AECCAR0.txt
- (20.48 MiB) Downloaded 34092 times
Our chgsplit.pl script was not working with the vasp5 CHGCAR format. It is now, so you can download it again, or change the 10th line to:
for ($i=0; $i<6; $i++) {
Dear Prof. Graeme,
Sorry for very late return, due to the accident I had, I could not able to write.
I have changed the line 10 as you write and also tried with downloading new version but I still got the same error. When I type ./chgsplit.pl CHGCAR_sum
>Atoms in file: 68
is shown but nothing comes more. The file CHGCAR_mag is empty. Did I missed anything ?
thanks in advance
>Atoms in file: 68
thanks in advance
