As I know by the bader analysis, the transferred charge between two atoms in the unit cell can be seen, but , I was wondering how I can see the probable transferred charge between two different orbitals in the one atom of the cell? For example, I want to know how much charge are going from 4s orbital to 3d orbital of Ni atom in a specific metallic crystal.
By the way, the VASP is the program I am using.
Salman
Charge transfer between two different orbitals in one atom
Re: Charge transfer between two different orbitals in one at
This is not really part of the Bader approach. I suggest looking at the site-projected density of states, that you can do in vasp. Also, if you use DFT+U, you can get even more detailed information about the occupancy matrix around each metal center.
Thank you for your answer.
I knew about DFT+U, but I do not know how to interpret the result, I even wrote in VASP forume about it, but no answer I could get. For example below are the "occupancies and eigenvectors" of "Ni" and "B" atoms in one calculation, I would be appreciated if you could explain how I can found out the intera atomic charge or electron transferring in the d orbital of Ni. I know every column is related to different d suborbital in Ni (dxy, dxz,.....) , and (pxy,pxz,pxz) for p orbital of B, but not more.
Salman Zarrini
onsite density matrix for Ni
spin component 1
0.8418 -0.0082 0.0000 0.0000 0.0000
-0.0082 0.8405 0.0000 0.0000 0.0000
0.0000 0.0000 0.8413 -0.0080 0.0141
0.0000 0.0000 -0.0080 0.8283 0.0000
0.0000 0.0000 0.0141 0.0000 0.8623
spin component 2
o = 0.8233 v = 0.0000 0.0000 -0.5183 -0.8343 0.1881 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.8233 v = 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -0.5183 -0.8343 0.1881
o = 0.8329 v = 0.0000 0.0000 0.0000 0.0000 0.0000 0.6798 0.7334 0.0000 0.0000 0.0000
o = 0.8329 v = 0.6798 0.7334 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.8389 v = 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -0.7188 0.5441 0.4328
o = 0.8389 v = 0.0000 0.0000 -0.7188 0.5441 0.4328 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.8493 v = -0.7334 0.6798 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.8493 v = 0.0000 0.0000 0.0000 0.0000 0.0000 -0.7334 0.6798 0.0000 0.0000 0.0000
o = 0.8698 v = 0.0000 0.0000 0.4634 -0.0891 0.8816 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.8698 v = 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.4634 -0.0891 0.8816
onsite density matrix for B
spin component 1
0.1845 0.0000 0.0000
0.0000 0.1823 0.0053
0.0000 0.0053 0.2022
spin component 2
o = 0.1810 v = 0.0000 0.9702 -0.2425 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.1810 v = 0.0000 0.0000 0.0000 0.0000 0.9702 -0.2425 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.1845 v = 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.1845 v = 0.0000 0.0000 0.0000 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.2035 v = 0.0000 0.0000 0.0000 0.0000 0.2425 0.9702 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
o = 0.2035 v = 0.0000 0.2425 0.9702 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
Salman Zarrini
spin component 1
spin component 2
spin component 1
spin component 2
I think "charge transfer" here means charge distribution differences between Ni atom in the compounds and Ni atom in vacuum. If you already know the orbital occupations of isolated Ni atom, you just need to calculate the occupation numbers in the compound.
For the density matrix, the diagonal numbers are the number of electrons in the five d-orbitals, but there is no value for the s orbital that has no U applied.
As Graeme also suggested, the site projected DOS will give all the information you need. This can be done by setting LORBIT = 11.
