I am a newcomer in diffusion issues and maybe my question is quite naive, but is it possible to calculate diffusion length using AKMC code? If it is not, do you have any suggestions how to do this?
Thanks in advance!
Misha
diffusion length calculation
Re: diffusion length calculation
You can make a plot of distance^2 vs time for a diffusing species during an AKMC simulation. The slope will give you the diffusion constant. Alternatively, you can discover the diffusion mechanism(s) and use the Einstein–Smoluchowski relation to calculate the diffusion constant from the hopping distance and rate(s).
Thank you very much for your reply! What is a maximum number of atoms which can be treated using AKMC? I suspect that this number is restricted by VASP capabilities, but not sure.
Thanks in advance!
Misha
Thanks in advance!
Misha
There is no hard limit. Certainly with DFT, the cost will increase rapidly with system size.
Thaks a lot, Graeme! I'll try to calculate something )
