dimer example running failure
synlquan
Post by synlquan »
I have compiled a vtst code with VASP5.2. when I run dimer example (H/Ir) for the test, I got the following error message from out.
"The IMAGES tag should not be set for this implementation of the dimer method."
At the same time I do see some output from vtst in OUTCAR, and it stopped there.
" VTST: version 2.04a, (08/24/11)
CHAIN: initializing optimizer
OPT: Using Conjugate-Gradient optimizer
OPT: CG, Init
OPT: CG, FDSTEP 0.005000
OPT: CG, MAXMOVE 0.200000
CHAIN: Read ICHAIN 2
CHAIN: Running the Dimer method"
Anyone can point out where is compilation going wrong?
thanks!
Bo
