When running the 'bader' code on a pure vanadium 2x2x2 supercell (16 atom with ideal BCC positions), I get fluctuations in the charge of the vanadium atoms depending on their positions in the supercell. Typical variations are of order 0.05 in 13.00 electrons.
Is there a parameter I can change to decrease the magnitude of these unphysical variations?
thanks in advance for your advice.
Olivier.
Yes, one way to improve the precision is to use a finer charge density grid. You can do this by specifying NGXF, NGYF and NGZF in the INCAR file. I usually look in the OUTCAR or CHGCAR file to see what it is by default, and then multiply the default values by 1.5 or 2.
