I am attempting to perform a vibrational analysis on my system, which is a huge organic molecule (DMMP) adsorbed on a TiO2(110) oxide. However after the calculation was done, while extracting the frequencies using dymmatrix.pl, I encountered an error stating:
Building Hessian matrix
Illegal division by zero at /home/ctesvara/vtstscripts/dymmatrix.pl line 170.
I am trying to figure out where did I went wrong in my calculations. I ruled out the possibility of my VASP not being linked with vtst. Here I attachedmy OUTCAR. I greatly appreciate any advice I can get!
Illegal division error while using dymmatrix.pl
- dimer-results.rar
- (930.79 KiB) Downloaded 937 times
Re: Illegal division error while using dymmatrix.pl
This is our fault. There is a format change in how the atomic masses are written to the OUTCAR file. The attached script should work for your vasp.5.4 output. I will revise our script to autodetect the format and automatically read the appropriate format. For now, here is a working script.
- dymmatrix_v5.4.pl.gz
- (2.31 KiB) Downloaded 900 times
Dear Dr. Graeme,
It works wonderfully! Thank you very much for your prompt support!
