Question about CHGCAR ?
Damien
Post by Damien »
I would like to know what is exactely written in the CHGCAR file of VASP because I would like to extract more information than the information provided
using the Bader Charge analysis program (plane averaged charge density for example).
I did not find enough information in VASP forum so I was wondering if someone in this forum may help me.
Is it possible for example to evaluate a plane averaged charge density in electrons.m-2?
In the manual of VASP, they say that CHGCAR contains "rho.V". what does it means?
Thanks in advance,
Damien
Re: Question about CHGCAR ?
You have probably already seen this page, but it does concisely describe the format of the chgcar file:
http://cms.mpi.univie.ac.at/vasp/vasp/node66.html
Basically, it has the simulation box, atomic coordinates, and then a grid of charge density values.
Evaluating a plane averaged charge density is not difficult. If you are looking for a program or script to do this, you can contact Lijun Xu <xulijun@u.washington.edu>
rho.V is the actual charge density and V is the volume of a cell, so rho*V is the charge in that cell.
wren
Post by wren »
Hi there,
I was wondering if anyone could answer the simple question: What units does the CHGCAR file use? I've been googling left and right, and I'm fairly sure the VASP manual doesn't say...
Lusann
Wenjie
Post by Wenjie »
I think the unit used in VASP is number of electrons in each volume. Basically, it's the charge density at that grid point times the volume associated with one grid point.
