NEB energy oscillating
sinfire
Post by sinfire »
Hi all,
I'm doing a NEB calculation on oxygen dissociation.
As I checked the energies, it seems to be oscillating(or 'stuck' I'd say).
(The cnvg-f.txt file in the attachment is the result from
grep "F=" stdout
to look at E and dE)
Is this or common thing or should I rerun the calculation with different settings (like more finer EDIFF)?
Is there anything I can do other than waiting till the calculation converges?
For the note, I'm also doing a run with
IOPT=7
TIMESTEP = 0.01
but that job also seems to be oscillating.
Thanks in advance.
(I only included CONTCAR, OUTCAR, POSCARs in the attachment due to size issues)
NEB-O2-Ni.zip
(18.43 MiB) Downloaded 1016 times
Re: NEB energy oscillating
You don't have our VTST code linked into your vasp binary.
sinfire
Post by sinfire »
Thank you for the reply.
I noticed there's another executable and now it seems to be working.
VTST: version 3.1, (03/28/14)
CHAIN: initializing optimizer
OPT: Using VASP QUASI-newton optimizer
CHAIN: Read ICHAIN 0
CHAIN: Running the NEB
NEB: SPRING -5.000000
NEB: LCLIMB T
NEB: LTANGENTOLD F
NEB: LDNEB F
NEB: LDNEBORG F
NEB: LNEBCELL F
NEB: EFIRST 0.000000
NEB: ELAST 0.000000
I'd like to add another stupid question, so for my previous run,
VASP was running the NEB ignoring the LCLIMB option and using the old NEB method implemented in VASP, correct?
yes, that's right.
