bader problem about paw GGA Ga
yangjio4849
Post by yangjio4849 »
My issue contains Ga atoms. When I done the VASP scf for it, bader CHGCAR, I found all the charge of Ga is zero!! All the electrons are redistributed to the connected atoms.
But if ICHARG=12 in INCAR, it works normally, and the total charge for Ga is 2.9x, very close to 3. And nothing special found when doing charge difference analysis with lev00.
The potential is PAW PBE of Ga with only 3 electrons.
Any suggestion?
Re: bader problem about paw GGA Ga
Did you add the core charge using the method explained here:
yangjio4849
graeme wrote:Did you add the core charge using the method explained here:
bingo!
