Dear all and especially Prof. Graeme,
Attached is the ball-and stick structure of a homogeneous catalyst monomer that I am working on. The atom at the center and in dark yellow is iron (Fe), linking to two ligands.
I was trying to search the transition state (TS) of dihydrogen molecule splitting (H2 -> H + H) on the Fe atom of the monomer by the dimer method. During the TS search, I have of course allowed H2 or two H atoms to relax; also, I have allowed all atoms of the catalyst monomer to move, in which a lot of degrees of freedom are on the run. But the VASP job by the dimer method failed to find a meaningful TS.
Does it indicate that I should fix all atoms of the catalyst monomer and only allow the two H atoms to move ? Is it valid ?
During a TS search, freeze the catalyst or not ?
- molecule.jpg (47.85 KiB) Viewed 11355 times
Re: During a TS search, freeze the catalyst or not ?
It sounds like you know both the initial and final states of your reaction of interest. I suggest using an NEB calculation to find the saddle point that connects them.
Prof. Graeme, thanks for the heads-up. I will run the NEB method first.
