DOS projection in Bader volume for VASP 5.4
brightzhang
Post by brightzhang »
Hey Graeme,
Do we have DOS projection in Bader Volume for VASP 5.4? There was one for older versions of VASP?
Best
Liang
Re: DOS projection in Bader volume for VASP 5.4
This is a good question and one that keeps coming up. I've promised to look into this and a little extra motivation is helpful. It might just require a simple update to the installation script -- I will get to this by spring break, for sure!
brightzhang
Thanks! One of my colleagues asked me for it. I have also suggested him to follow the update on this forum.
I've updated the mkbrdpro.pl script in vtstcode to work with vasp 5.4 so that it builds now.
Some instructions can be found at this old page: http://theory.cm.utexas.edu/vtsttools_old/dos/
One difference is that you should not change the makefile; instead, change the /src/.objects file by adding the bdrpro.o object after the sphro.o object:
sphpro.o \
bdrpro.o \
I have not tested to see if it works yet, so if anyone does try it I would be very interested to know if there are any problems. If it does work, I'll update the documentation and maintain this functionality moving forward.
