Do not set LAECHG=.TRUE. in the new VASP version?
jianmin
Post by jianmin »
Dear Prof. Graeme,
I am learning how to perform the Bader charge analysis. I was told that I should set LAECHG=.TRUE. in the INCAR file and then run the job. By this I will get the corresponding output files AECCAR0 AECCAR1 AECCER2. But I don't see this piece of information in the webpage: http://theory.cm.utexas.edu/henkelman/code/bader.
Does it mean that for the latest version of Bader, running the "bader chargefile" conmmand is enough?
Re: Do not set LAECHG=.TRUE. in the new VASP version?
The information is past half way down that page under the section entitled: Note for VASP users
jianmin
Post by jianmin »
Thanks for the tip. Problem solved.
