increasing precision of calculation
oasd001
Post by oasd001 »
Dear developpers and users,
When running the 'bader' code on a pure vanadium 2x2x2 supercell (16 atom with ideal BCC positions), I get fluctuations in the charge of the vanadium atoms depending on their positions in the supercell. Typical variations are of order 0.05 in 13.00 electrons.
Is there a parameter I can change to decrease the magnitude of these unphysical variations?
thanks in advance for your advice.
Olivier.
Yes, one way to improve the precision is to use a finer charge density grid. You can do this by specifying NGXF, NGYF and NGZF in the INCAR file. I usually look in the OUTCAR or CHGCAR file to see what it is by default, and then multiply the default values by 1.5 or 2.
andri
Post by andri »
A good thing to try a well is to converge the electronic structure using a smaller than usual EDIFF value, something like 1E-8.
Andri, have you seen a smaller ediff value (going from a normal value of 1e-5 to to a smaller value of 1e-8) effect the bader charges?
andri
Post by andri »
I can't recall any specific instances but I'm pretty sure that decreasing EDIFF as helped me in the past to reduce noise in the charges.
