Incorrect calculation - Client 1.18
M Cluster
Post by M Cluster »
The new client 1:18 produces only error in the calculation.
Does anyone have an idea that lies ahead?
Greetings
8474076 17621489 1 Dec 2010 10:43:37 UTC 1 Dec 2010 10:55:58 UTC error computing 1:13 0:00 --- eon Client v1.18
nullcoding
Re: Incorrect calculation - Client 1.18
Post by nullcoding »
Same problem here.
The 727560067-xxxxx WUs seem to run indefinitely. One had run for two hours and the progress bars all read 0.000%. I've suspended the project because there's definitely something wrong with the new client.
OSX 10.6.5 on Intel i5, by the way.
chill
Post by chill »
I'm looking in to this. Could everyone, who hasn't said already, please tell me their operating system? If you run linux the output of uname -a would be nice. I have setup a new build process for compiling the client for all four platforms, and I did a small beta test and everything seemed to work, but these problems might be related to that. The one error I see now is that any linux computer with a kernel older than 2.6.27 will error out. I have fixed this and have new linux binaries I'll push out soon. But I'm not sure about this long workunits that aren't finishing. I have to check and see whats going on.
chill
Post by chill »
I'm looking in to this. Could everyone, who hasn't said already, please tell me their operating system? If you run linux the output of "uname -a" would be nice. I have setup a new build process for compiling the client for all four platforms, and I did a small beta test and everything seemed to work, but these problems might be related to that.
The one error I see now is that any linux computer with a kernel older than 2.6.27 will error out. I have fixed this and have new linux binaries I'll push out soon. But I'm not sure about these long workunits that aren't finishing. I have to check and see whats going on.
chill
Post by chill »
It looks like the stuck workunits are a bug in our code (not a bad client). It current is possible for the code to get stuck in an infinite loop. I'll fix this at the same time that I update the linux binaries.
upstatelabs
Post by upstatelabs »
I'm having the same problem as nullcoding with some of the 727560067-* WUs, the WU just keeps running but makes no apparent progress. One machine I've had this on is a win2000 SP4 running BOINC 6.10.43, another is a winXP SP3 running BOINC 6.6.20. I have several others but haven't checked them yet.
edit: wu #'s
Update: After some checking, I have found that several of these 727560067-* WU's have completed successfully on my machines. Just not all.
Phil P
Post by Phil P »
I aborted 2 after an hour on each, and got 2 more.
I'll give them a few hours and see if they wake up.
nullcoding
Ah...infinite loop. Long timescale dynamics. Haha.
Well okay - glad it's not the client. Seems like there has been a new client version every couple of days recently. Good thing it's not an issue with having developed them too fast or something like that.
Thanks for the update.
Robert Pick
Post by Robert Pick »
some of the 171 WU's are doing the same thing!
I'm running an i7, xp,sp3.
chill
Post by chill »
I turned off the problematic simulation. We are currently working on coding up a fix for this type of simulation so that it cannot get stuck.
Beyond
Post by Beyond »
All my machines WUs errored out too. Unfortunately eon left some of the machines in a state where they were unstable, causing other projects both CPU and GPU to error.
matob
Post by matob »
I had cancelled a few erroring WUs maybe an hour ago...
http://eon.ices.utexas.edu/eon2/result. ... id=8755661
