Potentials on OS X
Python framework for working with atomic configurations, potentials, and algorithms.
Potentials on OS X
Post by graeme » Sat Nov 05, 2005 7:37 am
The potentials can now be built on osx by running the Gman/pot/build_osx_xlf script. This is nothing fancy, but it's better than it was. This requires that xlf, f2py, numeric, and scipy to be installed.
Re: Potentials on OS X
Post by graeme » Sun Apr 13, 2008 8:30 pm
Things have changed a bit since that post (in 2005). The framework is now called TSSE, and it can be downloaded by following the instructions on the page: http://theory.cm.utexas.edu/henkelman/code/
The only module now required is numpy - this replaces numeric, scipy, and f2py.
The potentials are also now built just by running 'Make' in the main TSSE directory.
