GPAW with Hirshfeld analysis
Python framework for working with atomic configurations, potentials, and algorithms.
wojciech
Post by wojciech » Fri Feb 19, 2016 6:40 pm
Hi all,
This is my first post and I don't know if I'm in right place for asking such kind of question so please, be patient.
I'm trying to perform Hirshfeld volumes analysis via ASE/GPAW. I writed input code for first test. GPAW performed calculations but I can't see Hirshfeld volumes in the output. Any ideas?
#!/usr/bin/python
#from gpaw.output import PAWTextOutput
from gpaw import GPAW
from ase.visualize import view
from ase.io import read
from gpaw.analyse.hirshfeld import HirshfeldPartitioning
atoms = read('neon_dim.xyz')
atoms.center( vacuum = 2 )
#view( atoms )
calc=GPAW(
xc='PBE',
mode='lcao',
txt='neon_dim.log',
basis='dzp',
h=.2,
#verbose=1
atoms.set_calculator(calc)
atoms.get_potential_energy() # Calculate the total energy
cc = HirshfeldPartitioning(calc)
atoms.set_calculator(cc)
cc.get_effective_volume_ratios()
Wojciech
wojciech
Re: GPAW with Hirshfeld analysis
Post by wojciech » Fri Feb 19, 2016 9:36 pm
Hi again,
Delete this post please. Answer was obvious:
print cc.get_effective_volume_ratios()
sorry for spoiling forum,
Wojciech
