Updated dimer.F
Updated dimer.F
Improved formatting for the out.dat file was checked into cvs. I also added a routine to deal with periodic boundaries into dimer.F.
Chain.F no longer prints that it is doing an NEB calculation for regular vasp runs.
I've updated the tar file.
hou
Re: Updated dimer.F
Post by hou »
graeme wrote:Improved formatting for the out.dat file was checked into cvs. I also added a routine to deal with periodic boundaries into dimer.F.
There exists tiny bug at 218, 219 and 300 lines in dimer.F.
218 line: !subroutine Chain_Init(T_INFO,IO)
219 line: subroutine Dimer_Init(T_INFO,IO)
300 line: end subroutine Chain_Init
What is the subroutine to be defined? Chain_Init or Dimer_Init?
From the tests, I guess that it should be subroutie Dimer_Init. Is it righit?
Thanks!
The name of the main routine has changed over time, and the older names, such as chain_init, are still present as comments in the code.
I've removed the old calls to clearify the code, leaving dimer_init and dimer_force. This is updated in cvs. These changes should not affect the building or running of the dimer method.
mail test
test
