Hi folks,
I am in need of some expert help. This question may be trivial to some of you but your input will be quite helpful for my manuscript.
NEB calculation has converged but if I go into individual image directory and run vef.pl or vef.py, I get a certain Force vs Ionic steps graph....
BUT, if I run nebresults.pl script in the parent directory, the forces are different and much smaller.
I don't know which graph to trust. I have attached both graphs here and your advice would be very much appreciated.
vef.pl and nebresults.pl provide different forces for the same run - expert advice needed!
- nebresults.pl script
- Image2_nebresults_script.png (50.3 KiB) Viewed 11955 times
- vef.pl script run within the image directory
- Image2_vefpl_script.png (48.22 KiB) Viewed 11955 times
Re: vef.pl and nebresults.pl provide different forces for the same run - expert advice needed!
If you attach a tar.gz file of the simulation I can help with this question. Most likely there is a simple explanation - the NEB forces are composed of only the real forces perpendicular to the path plus a spring force to keep the images equally spaced. For convergence, you should look at the NEB forces.
Many thanks for your prompt response!
I have attached the entire simulation with OUTCARs in the respective image folders. [File name = neb.zip, around 396 MB]
Your explanation will help me understand the conceptual framework better. Very grateful for your help.
- neb.zip
- Entire NEB simulation file
- (396.5 MiB) Downloaded 1698 times
I have attached the results in the post above.
Many thanks for your Prof. Henkelman.
> at the NEB forces.
> at the NEB forces.
